Finally finished the fiberglass inlet to the air box. Had to thicken up the walls with cloth and resin, then trim to be about 1/4" from the air box when cowl installed. Then installed the seal so when cowl is in place the space is now sealed. Should be a slight vacuum here until ram air out strips the engine needs for air.
